It is currently Thu Aug 14, 2025 2:20 am
 Post subject: Fretboard thickness
PostPosted: Sat Sep 05, 2015 3:00 am
Hi
Getting to the stage where i can tackle the fretboard fitting as the necks nearly done
Bit more work needed on the neck angle but then it hit me.. what about the fretboard thickness?
Does it need to be the same thickness as the bridge as a rule or is there other methods/formulas etc
Any info would be greatfully received :)
 Post subject: Re: Fretboard thickness
PostPosted: Sat Sep 05, 2015 5:49 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I start with a flat fingerboard that is 1/4 inch thick, then radius it, trying to leave the middle at the original 1/4 inch thickness.
These users thanked the author doncaparker for the post (total 2): unkabob (Sat Sep 05, 2015 2:24 pm) • cablepuller1 (Sat Sep 05, 2015 6:14 am)
PostPosted: Sat Sep 05, 2015 7:47 am
First name: D
Last Name: S
That's a nice looking guitar!
I do the same as Don, for no particular reason.
Dan
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: cablepuller1 (Sat Sep 05, 2015 8:12 am)
PostPosted: Sat Sep 05, 2015 8:08 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
You should set the neck so that the tops of the frets hit right at the top surface of the bridge when the neck is straight (no relief). Standard thickness for fretboards is .250.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: cablepuller1 (Sat Sep 05, 2015 8:13 am)
PostPosted: Sat Sep 05, 2015 12:45 pm
First name: Alan
Last Name: Jones
City: Cobble Hill
State: British Columbia
I am the same, .250" but I am a bit different with my neck carve....I have the fretboard glued to the neck before I start to carve it. I find it makes the transition of fretboard to neck less visible if both are carved and sanded together.
Blue Ring Acoustics
blueringacoustics.ca
These users thanked the author tysam for the post: cablepuller1 (Sat Sep 05, 2015 1:25 pm)
PostPosted: Sat Sep 05, 2015 1:24 pm
0.250" on the fretboard thickness. I also glue the radiused, unfretted board to the neck before carving.
These users thanked the author SteveSmith for the post: cablepuller1 (Sat Sep 05, 2015 1:25 pm)
PostPosted: Sat Sep 05, 2015 2:33 pm
City: winnipeg
State: manitoba
Country: canada
I fret first and glue in place on a carved neck and then blend it in using the "shoeshine" technique using 80 and/or 120 grit.
A straight-edge at the center of the frets should kiss the top of the bridge.
Bob :ugeek:
These users thanked the author unkabob for the post: cablepuller1 (Sat Sep 05, 2015 3:11 pm)
PostPosted: Sat Sep 05, 2015 3:15 pm
Bridges are typically 3/8 thick with about 1/8 of saddle coming out to give the 'standard' 1/2 string height over the soundboard. I aim for 1/4 fingerboard thickness.
These users thanked the author meddlingfool for the post: cablepuller1 (Sat Sep 05, 2015 4:29 pm)
PostPosted: Sat Sep 05, 2015 4:03 pm
Well, gee whiz, wouldn't you just know it, mine were different. Because I rabbited the binding into the fingerboard, mine were 5/16" thick. Binding ends up about 3/16" as there is about 1/16" radius on the edge. Just the Larson way of doing it...
These users thanked the author Haans for the post: cablepuller1 (Sat Sep 05, 2015 4:30 pm)
PostPosted: Sat Sep 05, 2015 6:37 pm
First name: Greg
Last Name: B
City: Los Angeles
Clearly .25" is traditional. However, my personal preference is 5/16" also, with non adjustable reinforcement. I did one the Larson way with rabbeted fretboard binding as Haans describes. It looks nice.
These users thanked the author Greg B for the post: cablepuller1 (Sun Sep 06, 2015 2:11 am)
PostPosted: Sat Sep 05, 2015 8:23 pm
I just had a Larson Brothers guitar come into my shop and saw the rabbited fretboard binding and loved it. It is definitely in my future.
I carve the neck after the unfretted board is attached. .250 thick prior to radius.
These users thanked the author Terence Kennedy for the post: cablepuller1 (Sun Sep 06, 2015 2:11 am)
